#1 2021-07-18 03:14
grepmoth
Delete the first parentheses and it's content
Example:
Original Name: Sample song (year) (artist).mp3
After ReNaming: Sample song (artist).mp3
Basically I want to delete the first parentheses and it's content. How to do it?
Thanks!
#2 2021-07-18 10:52
eR@SeR
Re: Delete the first parentheses and it's content
Try this RegEx rule:
1) Regular Expressions: Replace expression "\(.+\) (\(.+\))" with "$1" (skip extension)
#3 2021-08-08 08:56
grepmoth
Thanks It works.
I was having trouble with the code. Finally figured it out. So I'm sharing the screencap if anyone else is also confused...
However... It only works if the parentheses are side by side together. Is it possible to do the same thing even if there's something between the parentheses.
Example
Input: Text (p1) randomtext (p2)
Rename: Text randomtext (p2)
Thanks.
#4 2021-08-08 20:23
Text (p1) randomtext (p2).ext
Text randomtext (p2).ext
Goal:
Try to match null-or-more of any sign ".*" between the parentheses:
Note that there is still at least one space matched between the parentheses in the above expression.
You may remove that space if not need to match for to work f.ex. on: "Text (p1)(p2).ext"
See for reference > den4b.com/wiki/ReNamer:Regular_Expressions
. >>> one of any sign (the symbol is just a dot)
* >>> zero or more of the expression before
+ >>> one or more of the expression before
? >>> zero or one  of the expression before
