Occasionally I would like to measure the (run)time of some long-running programs (video conversion or mathematical calculations).
Therefore I need an Event such as the existing "CPU usage" but with monitoring TWO parts:
- activate Event if CPU usage is increasing above 5%
and
- end Event if CPU usage falls below 5%
The triggered Action should show the time between the two events parts.
This way I could start Shutter with this double-event preset, then prepare and start the monitored program and finally let the calculations run for hours/over night.
How can I achieve this?
You can sequence such events to be monitored one after another by selecting the 1BY1 logic in the dropdown located above the events table. However, there is no straightforward way to display the time taken between the triggered events.
Perhaps there are other tools available which are specialized in tracking the activity of other applications.
