#1 2021-05-05 15:24
Lauraq
Add a increasing two-digit number at the beginning of the file: 01,02
Hi smile
I have a list of files named by date, for example
2021-04-11
2021-04-18
2021-04-25
It is possible to add a two-digit number, increasing at the beginning of the file, to obtain:
01 - 2021-04-11
02 - 2021-04-18
03 - 2021-04-25
Thank you so much
#2 2021-05-06 18:59
Re: Add a increasing two-digit number at the beginning of the file: 01,02
Yes, you can do this using the Serialize rule.
The extra hyphen " - " can be added using the Insert rule.
#3 2021-05-06 21:15
Lauraq
Fantastic, thank's smile
A leattle problem, I have this result
https://ibb.co/sqyRQ5J
How can I add the "0" to the first 9 numbers?
#4 2021-06-06 22:02
skiwi
In the Serialise option select the "Pad with zeros to length" option and change it to 2
#5 2021-06-06 22:11
Lauraq
sorry my wrong...your help work correctly..many thank!!! smile
