Hi guys! :-)
Is it possible to add the folder name as prefix to file names within this folder?
Example (folder and content):
BEFORE:
D:/Images/Trains/OHE-1200/
AFTER:
Fiorellino
Yes, you can do this using the Meta Tags feature.
Basically, you need to insert the ":File_FolderName:" meta tag via the Insert rule.
Crazy, it works! I was searching for it, but I oversaw it in the metatag list.
Many, many thanks!
