#1 2021-03-18 17:51
LemonPeeler
Reset the opening default window size for Renamer?
Don't know if others have noticed this, but RENAMER opens with a relatively small window size compared to other applications.  Ironically, we have a large 27" screen and there is no lack of screen real estate.  However, since the window opens in a smaller size than most, it is generally ineffective and must be increased to a larger size each time in order to see the complete file and path names in the two name columns (original and modified) in the default window.  This becomes a frustration when repeatedly opening Renamer.
How can we change the default size of the opening window in RENAMER?  Most other Windows apps open with a default size of the last closed window for the program.  But RENAMER always opens too small.
#2 2021-03-18 18:49
Re: Reset the opening default window size for Renamer?
There is an option in the Settings that should help you:
"Remember position and size of major windows"
#3 2021-09-02 19:09
LemonPeeler
Sorry for the delay, but so grateful for the very simple solution to opening the initial program window in a larger size!!
