#1 2021-03-07 02:10
steve
support exif for ARW raw files
Could you add support for ARW raw files?
RAW File; Sony NEX-6; ARW; RAW
drive.google.com/file/d/133yy5WMgAY65pEzKw6Pc0_qm0L3RXdll
More Details; on a Google Docs Document;
docs.google.com/document/d/10_q1QsGtvpNzmV2-5msGKpAxztzAJHvHhm4JeRSvArI
(use zoom;fit )
Thanks!
Steve
#2 2021-03-08 20:27
Re: support exif for ARW raw files
There is no built-in support for ARW image files, but you can use 3rd party tools in combination with ReNamer to achieve the desired result.
For example, see the following scripts:
https://www.den4b.com/wiki/ReNamer:Scripts:Exiv2
https://www.den4b.com/wiki/ReNamer:Scripts:ExifTool
