#1 2021-03-03 03:46
luisxv2k
How to move the final part of the file name to a position at the begin
Hi all!
I´m back!
I have the code bellow that remove duplicate text in file name as showed in examples bellow that was solved in another topic.
The code is ok and functional until this moment. Thanks for your precious help again!
  t1,t2,t3:WideString;
  amount:Integer;
  amount:=7;
  //WideCopy(String, Index, Count) Syntax
  t1 := WideCopy(FileName,1,amount);        //Copy first  7: Start from pos 1, take 7
  t2 := WideCopy(FileName,amount+1,amount); //Copy second 7: Start from pos 8, take 7
  t3 := WideCopy(FileName,amount+1,999);    //Copy wanted name: Start from pos 8, take till the end
  If(t1=t2) Then FileName := t3;
Example A: From
SBBI - SBBI - ADC.pdf
SBBP - SBBP - VAC.pdf
SBBQ - SBBQ - ADC.pdf
SBBR - SBBR - ADC.pdf
SBBV - SBBV - PDC.pdf
SBCA - SBCA - VAC.pdf
Exemplo B: To
SBBI - ADC.pdf
SBBP - VAC.pdf
SBBQ - ADC.pdf
SBBR - ADC.pdf
SBBV - PDC.pdf
SBCA - VAC.pdf
But now, at last, I have another need.
I´m need to move the last 7 characters before extension of the file name to position 5 of the same filename and to reach the final desired results.
Examples:
    SBSP - BUVGU.1A - RWY 17L - 17R - XSID.pdf
    SBSP - CPN.1B - RWY 17L - 17R - STAR.pdf
    SBSP - IAC - RNAV - GNSS - S - RWY 17L - XIAC.pdf
To:
    SBSP - XSID - BUVGU.1A - RWY 17L - 17R.pdf
    SBSP - STAR - CPN.1B - RWY 17L - 17R.pdf
    SBSP - XIAC - IAC - RNAV - GNSS - S - RWY 17L.pdf
Question: What is the best line of code to implement this new need?
Thank you again!
#2 2021-03-03 16:09
Re: How to move the final part of the file name to a position at the begin
The new problem can be solved more elegantly with a Regular Expressions rule:
> Replace expression "\A(.+?) - (.+) - (.+?)\Z" with "$1 - $3 - $2" (skip extension)
The old problem can also be solved more elegantly with a Regular Expressions rule:
> Replace expression "\A(.+?) - \1 - (.+)\Z" with "$1 - $2" (skip extension)
Both rules use the " - " delimiter to identify the needed parts.
For the reference:
#3 2021-03-03 20:47
luisxv2k
I definitely convince myself that I have to learn how these Regular Expressions work, and without a doubt they work excellently!
Thank you again!
One more problem solved!
