#1 2021-02-24 07:37
nkormanik
Enhancement Request: Rules for entering files/folders can now be saved
Nice new idea:
Allow for saving "rules" for entering files/folders into list of files/folders to be acted upon.
Just as now there are rules for acting upon files and folders.  A large set of rules, in fact.  How about allowing for rules to create the list of files/folders to begin with.
For instance:
-- rule #1 -- All the files in c:\a.  In other words, c:\a\*.*
-- rule #2 -- Well, you missed a key folder there as well.  So, I'll be explicit, also include the folder in c:\a\, c:\a\results\.  (That's a folder, "results".)
If there is a way of doing the above that I'm not yet aware of, please tell me.
Thanks much!
Nicholas Kormanik
#2 2021-02-24 11:37
Re: Enhancement Request: Rules for entering files/folders can now be saved
There is no visual interface to pre-program which files or folders to add, but you can do that using the command line interface, which is very commonly used for sending files/folders to an application.
For example:
"C:\Path\To\ReNamer.exe" "c:\a" "c:\b" "c:\x\*.mp3"
You can create a shortcut to ReNamer and specify your arguments in the shortcut details, which will allow you to launch ReNamer and add your desired files/folders automatically. The command line interface also lets you load a preset and rename files automatically.
#3 2021-02-24 12:09
nkormanik
Sounds good to me.  Will go the route you suggest.  Thanks much for getting back so swiftly.
Hope all is fine in your neck of the woods.
#4 2021-02-24 16:43
All good here! Keeping safe and sane smile
