#1 2021-01-20 15:30
SoerWeiwel
Exchange names before and after hyphen
OLD: The Beatles - Strawberry fields
should be new: Strawberry fields - The Beatles
how can i manage this ?
Thx in advance
PS: If possible answer in german language
#2 2021-01-20 16:13
Re: Exchange names before and after hyphen
You can use the Rearrange rule to swap parts of the filename based on a delimiter.
Rule configuration:
* Split using: Exact pattern of delimiters
* Delimiters: " - "
* New pattern: "$2 - $1"
For the reference:
https://www.den4b.com/wiki/ReNamer:Rules:Rearrange
https://www.den4b.com/wiki/ReNamer:Rule … e_Examples
#3 2021-01-20 23:45
SoerWeiwel
Many Thanks for your help:)! It works!:)
