#1 2021-01-19 10:36
galbur
Replacing spaces with underscore
Hi
Same problem as described in Topic #2459.
I did everything as described but without any effect.
Screenshot
Thank you
Christoph
#2 2021-01-19 18:39
Re: Replacing spaces with underscore
The "Name" column shows the original file name.
Please inspect the "New Name" column. This is where you see the new file name, after applying the modifications.
#3 2021-01-20 09:44
galbur
Hi and thanks a lot
That was the problem. For some Reason the Column "New Name" was out of Focus.
All the best
Christoph
