Hello, I have had Renamer on the same laptop for years, and want to move it to my new one. A couple of my presets seem to not exist as rnp files. Whenever I load them, they load fine, and I can make changes, but they do not get saved to any installation or userdata folders, they are just... there, in the program. Also, if I run Renamer as administrator, they will not load. Is there any place they could be in the registry or some such so that I could copy them? I'd love to give the old laptop a clean install for a new task but I can't lose those presets, and one or two of them have a lot of rules to do by hand again. Thank you very much in advance for any advice or help.
The first place to try is the Main Menu > Presets > Browse...
If that doesn't open the folder with your presets, then you might be affected by the VirtualStore concept of Windows.
See this article for more information on how to find ReNamer's data:
https://www.den4b.com/wiki/Application_Data_Storage
Thanks! It was the VirtualStore issue, and I found them there.
