#1 2021-01-01 23:16
Rincewindwiz
Pad out numbers
Hi
I have a bunch of files that are named with a string of "text" + "-"+a number+".extension"
The number does not have leading zeroes so the files appear in the wrong order
text-1.ext
text-10.ext
text-100.ext
text-101.ext
And I want
text-001.ext
text-002.ext
text-003.ext
etc
So I want to replace
"text-?.ext" with "text-00?.ext" and
"text-??.ext" with "text-0??.ext"
But it seems ? is not allowed in the replace part of a rule
So how can I pad out the numbers with leading zeros?
TFAI
On a more general note, it would. IMHO, be very useful to be able to use ? and * in the replace part where they refer to the character(s) that they replaced in the find part of the command.
#2 2021-01-05 14:01
Re: Pad out numbers
You can use the Padding rule to apply the zero padding to existing numbers.
See https://www.den4b.com/wiki/ReNamer:Rules:Padding
Regarding the second question. You can enable an option to interpret wildcards and back-references in the Replace rule.
See https://www.den4b.com/wiki/ReNamer:Rules:Replace
#3 2021-01-05 22:53
Rincewindwiz
Re: Pad out numbers
Padding: That's very clever. I thought it only applied to numbers being added. Silly thought really as that is in serialise
Not sure I get backreferences
I'll have a play and see if I can work it out
Thx
#4 2021-01-06 00:14
Re: Pad out numbers
That would be:
"text-?.ext" with "text-00$1.ext" and
"text-??.ext" with "text-0$1$2.ext"
With wildcards and back-references in the Replace rule.
#5 2021-01-06 17:14
Rincewindwiz
Re: Pad out numbers
Thank you.
And if I have understood it correctly,
TextABCD-1.ext -> TextABCD-001.ext
TextADCB-1.ppt-> TextCDAB-001.ppt
TextZZ-2.xls   -> TextZZ-002.xls
TextXXX-13 .txt  ->  TextXXX-0013.txt
can all be done with
Find        Text*-?.*
Replace  Text$1-00$2.$3
with wildcards and backrefs ticked
#6 2021-01-06 20:24
Re: Pad out numbers
TextXXX-13.txt  ->  TextXXX-0013.txt
Find        Text*-?.*
The first 3 examples should work, but the 4th example will not.
"TextXXX-13.txt" will not match the "Text*-?.*" pattern, because "?" matches exactly 1 character.
This is where you should start using Regular Expressions instead of Wildcards.
