Hi, i want to rename my movie collection.
Movie.1990.mkv
Movie (1990).mkv
If you want to enclose all 4 digit sequences in parentheses, you can use the following Regular Expressions rule:
> Expression: "\b(\d{4})\b" (without quotes)
> Replace: "($1)" (without quotes)
Note that this particular configuration will also insert parentheses where you already have parentheses. In order to avoid the duplicated parentheses you can either remove them in a separate Replace rule, replacing "((" with "(" and "))" with ")", or use a more complicated Regular Expressions rule as follows:
> Expression: "(\A|[^\(])\b(\d{4})\b([^\)]|\Z)" (without quotes)
> Replace: "$1($2)$3" (without quotes)
There is a lot more happening to avoid inserting duplicated parentheses.
As to those dots, you can replace them with spaces via the Clean Up rule.
References:
https://www.den4b.com/wiki/ReNamer:Rules:CleanUp
Maybe this regex can solve more cases that you have using one rule...
1) Regular Expressions: Replace expression "[.( ]{0,2}\b(\d{4})\b\)?" with " ($1)" (skip extension)
Movie.1990.mkv
Movie 1990.mkv
Movie (1990).mkv
Movie.(1990).mkv
To:
Movie (1990).mkv
Movie (1990).mkv
Movie (1990).mkv
Movie (1990).mkv
Thank you very much. Tomorrow i will try it :-)
EDIT: Great! Thanks for support :-)
