#1 2020-12-20 15:02
narayan
Product idea: Configurable keyboard shortcuts to enter various texts
Hi
I downloaded a lot of research papers from the Internet, and now I am flooded with nonsensical file names; such as a large number, someone's name, "report", "Final", "Presentation", etc. The pdf name Pascal Script does not work on these files, which means they did not format the pdf files with proper format.
So I have to view each file in a quickviewer, press F2 and enter the name. (If the name is too long, I use an OCR tool, copy the name on clipboard and paste it).
But I also have many text snippets that I have to repeat (for example, "value chain analysis", "wastewater treatment", etc.) I'd like to have a software where I can store the text snippets, and which reproduces them with keyboard shortcuts.
So the software should reproduce multiple strings with an equal number of shortcuts.
But in the simplest case, it should store multiple text strings, but reproduce only one string with a single shortcut.
(The user has to select which of the stored strings to reproduce with that shortcut.)
#2 2020-12-21 18:09
Re: Product idea: Configurable keyboard shortcuts to enter various texts
Have you tried any clipboard managers?
They let you store many things in the clipboard simultaneously and access them via customizable shortcuts.
#3 2020-12-22 17:47
narayan
Well, I had never heard of them! Thanks for the tip!
