#1 2020-12-02 04:37
pstein
Bug: changed script in "Run Program" not remembered after restart
I setup Shutter v4.4 to run for an event "User inactive for 30 minutes"
with the actions
Run Program "D:\test\shuttertest.bat"
Utilities Restart events
It works.
Now I want to to change the script location. Therefore I do the following:
1.) Open running Shutter.exe from Systray
2.) Stop running exit by toolbar icon
3.) Click on the .bat script link in "Run Program" action
4.) Change the .bat script location in "Run Programs" to the new location "D:\tools\shutter\scriptmonitor.bat"
5.) Click "Save" button  ---->new Script location is shown in action sub pane
6.) Click on "Start" toolbar icon ---> it works
7.) Click "Exit" from Systray shutter icon
8.) Double click on Shutter.exe in installation folder
9.) The Action "Run Program" shows the OLD script location directory
Why does Shutter not remember the new, saved script location?
I think this is a bug.
#2 2020-12-03 07:55
Re: Bug: changed script in "Run Program" not remembered after restart
It looks like a bug indeed.
Terminating Shutter via the tray icon option does not trigger the process of saving the default preset. It may have been introduced by the recent upgrades of the development and the build environments. The fix is coming soon.
Thank you for reporting!
#3 2020-12-12 10:46
pstein
When will the fix version be released?
#4 2020-12-12 12:05
The fix is available in Shutter 4.4.0.6 Beta. Try the latest development version.
The release of this fix was delayed by the development of a new major feature.
