#1 2020-11-24 16:57
bulls23ant
Droplets/Links Stopped Working
Hi I have been using the droplets for a while by adding them to the send to menu and they have been working perfect, but now of all a sudden they stopped working. Both the load with preset and rename with preset stopped working and I also noticed that the send to renamer link is not working either. I tried reinstalling and even upgrading to the latest version but that didn't help. I'm on windows 10 and the current version of renamer is 7.2.
#2 2020-11-24 17:10
Re: Droplets/Links Stopped Working
Have you tried to regenerate your shortcuts/droplets using the Main Menu > Presets > Create Links option?
You can also test the commands directly from the Command Prompt or Power Shell:
https://www.den4b.com/wiki/ReNamer:Command_Line
#3 2020-11-24 18:19
bulls23ant
I had tried to recreate the links but not the command line. Interestingly enough when I tried to run a command I got this message:
'"ReNamer.exe"' is not recognized as an internal or external command, operable program or batch file.
I tried it both from a normal CMD windows and an elevated one but got the same result. Weird part is the program itself works fine.
#4 2020-11-26 03:08
bulls23ant
Just following up on this. Any ideas. I have tried reinstalling multiple times but get the same result.
#5 2020-11-26 13:52
You need to use the full path to "ReNamer.exe", unless "ReNamer.exe" is in your current working directory or in the %PATH% environment variable.
Example command:
"C:\Program Files (x86)\ReNamer\ReNamer.exe" /preset "My Preset"
