#1 2020-11-17 18:48
dirbik
Stop after first rule or conditional rules?
Thank you for this great tool.
I would like to add :EXIF_Date: to file names, however, if the :EXIF_Date: tag is blank or empty then add the :File_DateModified: tag instead.  What would be the easiest way to accomplish this?
Thank you
Windows 10 v10.0.18363
ReNamer Lite v7.2
Rule: Insert
Statement1:  :EXIF_Date:
Statement2:  :File_DateModified:
#2 2020-11-19 01:51
Re: Stop after first rule or conditional rules?
Currently, the only way to apply rules conditionally is to code them up in the Pascal Script rule.
For example, the script below will insert EXIF_Date meta tag if it is not empty, otherwise it will insert File_DateModified meta tag.
  TagValue: WideString;
  TagValue := CalculateMetaTag(FilePath, ':EXIF_Date:');
  if Length(TagValue) = 0 then
    TagValue := CalculateMetaTag(FilePath, ':File_DateModified:');
  if Length(TagValue) > 0 then
    FileName := TagValue + WideExtractFileExt(FileName);
Documentation: https://www.den4b.com/wiki/ReNamer:Pascal_Script
