#1 2020-10-26 03:11
rudiel97
I need to start a task when an ip Reply ping
that is, instead of "ping stops" it is "ping start".I want to ping an ip every 1 min and then when it is available start my tasks
Is it currently possible to achieve it? Or is there still nothing in the application that allows it?
Thx
#2 2020-10-28 22:53
Re: I need to start a task when an ip Reply ping
It is not possible currently, but this option will be added soon.
Keep an eye on this thread for updates.
#3 2020-10-28 23:43
rudiel97
OK thanks. I will be aware
#4 2020-11-14 22:35
This feature was implemented in Shutter 4.4.0.5 Beta.
Please try the latest development version.
#5 2020-11-15 00:19
rudiel97
Ok, thanks for your notice
