#1 2020-10-16 16:42
Crazyface
Adding a word to a string
Hi, First post.
I've been using Renamer for a while but have encountered a problem.
So I've figured out how to rearrange using $1 - $2     etc but if I wanted to add a word after swapping the stings around can I do this?
Eg
You - Are - Fine
To
$2 - $1 - $3 and want a beer?
Hope this is clear.
#2 2020-10-16 20:52
Re: Adding a word to a string
Yes, you can.
You can add anything you like in the pattern field.
Give it a try.
#3 2020-10-17 10:07
Crazyface
But how?
#4 2020-10-18 00:45
For example, using the Rearrange rule...
Split using: delimiters
Delimiters: " - "
New pattern: "$2 - $1 - $3 and want a beer?"
Input: You - Are - Fine
Output: Are - You - Fine and want a beer?
