#1 2020-09-17 14:26
sco
Feature Request - Change the font to a monospace font
it would be great if it would be possible to change the font in the window to a monospace font so you can easily see if all file names have the same length.
Alternatively it would be nice if you could have a column with the filename length.
Best regards from Austria and thank you for your great work.
Oliver
#2 2020-09-20 12:51
Re: Feature Request - Change the font to a monospace font
Hi Oliver.
An option for customizing the font is already on the feature todo list. So it is question of time and priority.
You can right-click on the column header to see the full list of available columns. That is where you can enable "Name Length" and "New Name Length" columns.
