#1 2020-06-15 07:05
dannician
Adding "1 of 3", "2 of 3", "3 of 3" etc... numbering to file name.
Is there a way to add a 1 of "number" to file names.
Folder
Result Folder
#2 2020-06-15 08:00
Re: Adding "1 of 3", "2 of 3", "3 of 3" etc... numbering to file name.
By using an PascalScript this would be possible
http://www.den4b.com/forum/viewtopic.php?pid=8669#p8669
#3 2020-06-15 08:30
Something like this:
  SerialNumber: Integer;
  FilesCounter: TWideStringArray;
    SetLength(FilesCounter, 0);
    WideScanDirForFiles(WideExtractFileDir(FilePath), FilesCounter, False, False, False, '*');
    SerialNumber := SerialNumber+1;
    FileName := WideExtractBaseName(FileName)
                + 'File ' +  IntToStr(SerialNumber)
                + ' of '  + IntToStr(Length(FilesCounter))
More info about PascalScript:
https://www.den4b.com/wiki/ReNamer:Rules:PascalScript
https://www.den4b.com/wiki/ReNamer:Pasc … Management
EDIT: script modified to reset file counter if folder name change
  CurrentFolder, LastFolder, SerialString: WideString;
    //get number of files in current folder into var 'FilesCounter'
   // WideScanDirForFiles(WorkDir, returnVar, Recursive, IncludeHidden, IncludeSystem, Mask);
    //increase file counter by 1:
   //reset file counter to 1 if folder name change:
    CurrentFolder := WideExtractFileDir(FilePath);
    if not WideSameText(CurrentFolder, LastFolder) then SerialNumber := 1;
   //Pad SerialNumber to wanted length (change "<1" to "<3" to get SerialString with at least three digits):
   SerialString := IntToStr(SerialNumber);
   While (Length(SerialString) < 1) Do
          SerialString := '0'+ SerialString;
    //compose new filename:
                + ' - File ' +  SerialString
    LastFolder := CurrentFolder;
#4 2020-06-15 15:57
dannician
The file counter script produces 0.
    WideScanDirForFiles(FilePath, FilesCounter, False, False, False, '*');
#5 2020-06-15 17:01
Ah, yes sorry, now already adjusted above.
"WideScanDirForFiles(FilePath" changed to "WideScanDirForFiles(WideExtractFileDir(FilePath)"
#6 2020-06-15 19:12
dannician
THANK YOU!  That is very close.  Now I see that there are more than just .jpg files in the folder that are being counted.  Is there a way to modify the script to only count .jpg files?
Found the solution in the Mask portion of the WideScanDirForFiles(WorkDir, returnVar, Recursive, IncludeHidden, IncludeSystem, Mask)
