This is the case:
My files have the following naming convention:
YYYYMMDD_COMPANY - OK - Subject.pdf ==> e.g: 20160810_Amazon - OK - invoice.pdf
I'd like to change that:
Amazon - OK - 20160810 - invoice.pdf
How can I manage this via ReNamer?
Thank you in advance.
Best regards
Hi and welcome.
USE:
1) Remove: Remove all "_Amazon - OK" (skip extension)
2) Insert: Insert "Amazon - OK - " as Prefix (skip extension)
3 - [Preview]
4 - [Rename]
For more details see http://www.den4b.com/wiki/ReNamer
HTH?
Thank you.
Amazon was just one example.
I have more than 10,000 files with the following naming convention: ==> YYYYYMMDD_COMPANY - OK - Subject.pdf
So how can I move the date after "OK - "? ==> COMPANY - OK - YYYYYMMDD - Subject.pdf
@xoksx "So how can I move the date after "OK - "? ==> COMPANY - OK - YYYYYMMDD - Subject.pdf"
It is there in Stefan's example.
Did you test/preview it on one of your files?
Step 1 (remove) will cause the date number to be at the beginning all by itself, momentarily.
Step 2 will cause the date to be after 'Company - OK - ...'
Just do each 'step => preview' one-at-a-time.
You would do the same thing for a different company but change the company name (provided they all follow the same format).
However, again, if they follow the same format, you should not be concerned with changing any names/words/numbers/characters/etc.
if you do this:
2 Rules:
First Rule- Replace (no quotes)
Find
'_'
Replace
tick 'first' and 'skip extension'
Second Rule- Rearrange (no quotes)
tick 'exact pattern...'
New Pattern
'$3 $4 $5 $6 $1 $2 $7'
tick 'skip extension'
It also works if you modify the second rule to,
[no qoutes]
tick 'Delimeters'
New Pattern
$2 - $3 - $1 - $4
There are probably some other variations but this is a start.
Hopefully I understand you and this helps.
- RWE
I would do it with a single Rearrange rule, like so:
> Rearrange: Split by exact pattern of delimiters "_", " - OK - ", New pattern "$2 - OK - $1 - $3" (skip extension)
Input:
20160810_Another company name - OK - another invoice.pdf
Output:
Another company name - OK - 20160810 - another invoice.pdf
Assuming that " - OK - " appears in all files.
Ahh, now!
Fine, another way to the above mentinoed...
USE:
1) Replace rule: Find all "_" Replace " - " (skip extension)
2) Rearrange rule: Split by delimiters " - ", New pattern "$2 - $3 - $1 - $4" (skip extension)
Don't use the "..." quotes, and note the well used spaces.
3 - [Preview]
4 - [Rename]
Or use one Regular Expressions rule to do that all together in one step:
Expression "(\d{8})_(.+? - )(.+? - )(.+)" Replace "$2$3$1 - $4" (skip extension)
For more details about the rules see http://www.den4b.com/wiki/ReNamer
@stefan
"USE:
3 - [Preview]
4 - [Rename]"
Is that another way of doing it or the same as what I suggested?...just curious.
- RWE
Hi Rnmr,
yes, you have had that exactly same idea already before I posted that,
if I take now a deeper look at your example, I see no differences to mine.
Sorry, I didn't spotted that fact beforehand.
