#1 2020-05-15 12:11
jpmb76
HTML and HEX are swapped?
I think there is an error within a program.
I believe HTML and HEX values are swapped.
screenshot
#2 2020-05-16 08:25
Re: HTML and HEX are swapped?
No, they are actually fine. But perhaps the labels could be improved to avoid this ambiguity.
The "HTML" format uses a hex notation but in a machine independent byte order, as used in HTML and CSS color specification. The "Hex" format is really a binary format in hex, it uses machine dependant byte order. The latter format is suited for pasting into various coding environments, e.g. C/C++, Pascal, etc.
#3 2020-05-16 08:46
jpmb76
Thanks for the info.
If you are going to change anything you could also change HSL order from what is now (HLS) to HSL.
#4 2020-05-18 09:09
Thanks for pointing this out. It appears that both conventions are used in the wild, but the latter (HSL) is defiantly more prominent.
It will be changed in the next version.
#5 2020-05-18 09:23
jpmb76
To be honest I don't recall to ever come across HLS mode
