#1 2020-05-11 12:51
lifestyle
Find and Replace By List - TXT CSV
I was download renamer, and found him very useful,
but now I need to change a bulk names, and looking for option to do it.
my problem is I wanna change the names by use option find & replace by using a list,
the list can be in format txt or CSV or any other format.
does you have any option to make it in your software?
Best Regards
Ilya Elkin
#2 2020-05-11 13:06
Re: Find and Replace By List - TXT CSV
Hi and welcome Ilya Elkin.
>>"find & replace by using a list"
Please see if that rule we suit you:
https://www.den4b.com/wiki/ReNamer:Rules:Replace
You can enter multiple search + replace strings at a time, each separated by  *|*
Also there is a "dictionary" PascalScript somewhere in the forum to correct misspelled words,
me think we can use that for multiple search&replace too.
Or use just an PascalScript with as many "WideReplaceStr()" lines as you need.
https://www.den4b.com/wiki/ReNamer:Pasc … g_Handling
https://www.den4b.com/wiki/ReNamer:Rules:PascalScript
https://www.den4b.com/wiki/ReNamer:Pascal_Script
Or try the translit rule:
https://www.den4b.com/wiki/ReNamer:Rules:Translit
