Hi
I have a large number of GPX files.
These contain many time metadata elements, e.g.
<time>2014-04-12T05:24:21.216Z</time>]
or
<time xmlns="http://www.topografix.com/GPX/gpx_modified/0/1">2014-04-12T05:27:03.774Z</time>
Can I get Renamer to extract the date and time of the first instance of one of these elements in the file and to insert the extracted date and time in a file name?
thanks
Simon
Sure, it is possible with the Pascal Script rule.
The script below will extract the content of the first <time> tag, and will insert it at the beginning of the filename.
You can adjust the script for a different placement, or use other rules to reformat and reposition the extracted content.
{ Extract first <time> tag content }
Content: WideString;
Matches: TWideStringArray;
Pos1, Pos2: Integer;
Content := FileReadText(FilePath);
Pos1 := WidePos('<time', Content);
if Pos1 > 0 then
Pos2 := WidePosEx('</time>', Content, Pos1);
if Pos2 > 0 then
Content := WideCopy(Content, Pos1, Pos2-Pos1);
Pos1 := WidePos('>', Content);
if Pos1 > 0 then
Content := WideCopy(Content, Pos1 + 1, Length(Content));
FileName := Content + FileName;
end
This is great thankyou.
I found the information about Pascal Script you provide better than any other information for it on the www.
I made a few changes in case you want to refer to it from the Scripts page.
{ Extract the first <time> element's content from GPX file
Input: GPX file with element similar to
Output: FileName prefixed by "yyyy-mm-dd hh.mm.ss " }
Content: WideString; { date time extracted from element }
Space = ' ';
Pos1 := WidePos('<time', Content); { find start tag of element }
if Pos1 > 0 then
Pos2 := WidePosEx('</time', Content, Pos1); {find end tag of element }
if Pos2 > 0 then
Content := WideCopy(Content, Pos1, Pos2-Pos1); { remove rest of line }
Pos1 := WidePos('>', Content); { find end of start tag }
if Pos1 > 0 then
begin { reformat datetime }
Content := WideCopy(Content, Pos1 + 1, Length(Content)); { extract timestamp }
Content := WideReplaceStr(Content, ':', '.'); { replace ":" with "." }
Content := WideReplaceStr(Content, 'T', Space); { replace T with space }
Content := WideReplaceStr(Content, 'Z', Space); { replace Z with space }
FileName := Content + Space + FileName; {prefix filename with datetime and a space }
end
PascalScript question:
I want to check in the above script that the extracted "Content" does actually contain a Date and Time string.
RegEx springs to mind, and I had a look at the useful Delphi Basics site, but I can't see any string operations that allow RegEx.
How could I go about checking that a string variable contains, say, a date?
Thanks in advance for any help
RegEx springs to mind, and I had a look at the useful Delphi Basics site, but I can't see any string operations that allow RegEx.How could I go about checking that a string variable contains, say, a date?
See the wiki for PascalScript functions to use within ReNamer.
wiki > ReNamer > Pascal_Script:Functions > Date_and_Time
http://www.den4b.com/wiki/ReNamer:Pasca … e_and_Time
Me think that functions could be of some use:
function TryEncodeDate(Year, Month, Day: Word; var Date: TDateTime): Boolean;
function TryEncodeTime(Hour, Min, Sec, MSec: Word; var Time: TDateTime): Boolean;
function TryEncodeDateTime(Year, Month, Day, Hour, Minute, Second, MilliSecond: Word; out ADateTime: TDateTime): Boolean;
function TryScanDateTime(const Pattern, Subject: String; out DateTime: TDateTime): Boolean;
this function returns TRUE or FALSE depending on the success of the operation
But I don't get it completely:
TryScanDateTime() returns an Boolean value as result, but why there is ALSO an "out DateTime" part?
Silly me would think """function TryScanDateTime(const Pattern, Subject: String): Boolean;""" would be enough for an Boolean result, no?
And then, also 'yyyy-mm-dd','20-12-05' return true?
My Test:
myDateTime:TDateTime;
myDateStr,strDateTime:String;
// Add your code here
myDateStr := '2020-05-17';
// // Note TryScanDateTime needs ReNamer 7.2 or newer
//TryScanDateTime(const Pattern, Subject: String; out DateTime: TDateTime): Boolean;
IF(TryScanDateTime('yyyy-mm-dd',myDateStr,myDateTime)) THEN
Showmessage('1: TRUE, date detected');
IF(TryScanDateTime('yyyy-mm-dd','20-12-05',myDateTime)) THEN
Showmessage('2: TRUE, but why?');
IF(TryScanDateTime('yyyy-mm-dd','example wrong',myDateTime)) THEN
Showmessage('3: TRUE');
end
else
Showmessage('3: FALSE, no valid date found');
//FormatDateTime(const Format: String; DateTime: TDateTime): String;
strDateTime := FormatDateTime ('yyyy-mm-dd',myDateTime); //DateTimeToStr
ShowMessage( 'Found date was: ' + strDateTime );
Perhaps I am completely on the wrong track?
For to check results by an RegularExpression comparison try
http://www.den4b.com/wiki/ReNamer:Pasca … xpressions
RegExSubPatterns: TWideStringArray;
// split the filename into parts by utilizing regular expressions:
//SubMatchesRegEx create an array of matches from expression in () parentheses:
//SubMatchesRegEx(const Input, Find: WideString;const CaseSensitive: Boolean): TWideStringArray;
RegExSubPatterns := SubMatchesRegEx(FileName,'(.*?)\[(\d+) by (\d+)\]',false);
if Length(RegExSubPatterns) <= 0 then exit;
--or--
RegExResult: TWideStringArray;
//MatchesRegEx returns an array of full matches, which matched the entire expression, not the sub-patterns.
//MatchesRegEx(const Input, Find: WideString;const CaseSensitive: Boolean): TWideStringArray;
RegExResult:=MatchesRegEx(myDate, '\d\d\d\d-\d\d-\d\d' false);
if Length(RegExSubPatterns) then
end
else
The out argument gets you the parsed date-time value, so that you can use it other functions, for example, reformat it in a different way, or adjust time. But if you only need to verify a particular format, then you don't need it.
It is a good question. What if the year is really just 20, rather than 2020? It could also be 200 and even 20000.
Should it expect 0 padding to exactly 4 digits, i.e. year "0020"? It seems a bit arbitrary.
For the reference, both FPC and PHP zero pad the year to exactly 4 digits when formatting using the long year format, but parsing does not require the 0 padding, so parsing "20" with the long year format produces year 20. Similarly, parsing day and month numbers with the long format also does not require the 0 padding.
Stefan wrote:TryScanDateTime() returns an Boolean value as result, but why there is ALSO an "out DateTime" part?
Thanks for explanation. It's just confusing without mention that fact in documentation and without examples how to use.
>>"then you don't need it"
But I have to USE it, or parser will report an error. I mention this just for reference.
Stefan wrote:And then, also 'yyyy-mm-dd','20-12-05' return true?
I just expect, if I check for _4_ digits , a _2_ digit result is not an match.
(And no, I do not expect 0 padding to exactly 4 digits!)
Me think I would rather like to use:
IF ( ('yyyy-mm-dd','20-12-05') OR ('yy-mm-dd','20-12-05') ) THEN
