Using 7.1.0.5 beta
There seems to be an error/bug in ':File_DateCreated:' and ':File_DateModified:' metadata
Typically, you have presented created and modified date formats as
'2020-04-11_11.39.03'
But two aspects are incorrect as '2020-04-11 11-39-03'
(space between date/time and a hyphenated time.)
The last 3 beta updates don't mention anything about this.
As a side note,
If I try to correct the underscore part, before renaming, by adding an underscore with 'insert' at 9th or
10th position (right-to-left), it adds an extra space before or after the underscore depending on the
placement position. I've rechecked my 'insert' rule to make certain there are no extra spaces inserted by user.
- RWE
Using 7.1.0.5 beta
'2020-04-11_11.39.03'But two aspects are incorrect as '2020-04-11 11-39-03'
(space between date/time and a hyphenated time.)The last 3 beta updates don't mention anything about this.
As a side note,
Hi Rnmr,
you may want to check out the settings:
http://www.den4b.com/wiki/ReNamer:Progr … s_settings
Meta tags settings
Date format
Sets the date format for ReNamer's use. (The selected date format will be used for naming files.)
Yes, I see now.
Sorry
I forgot that I changed that in Meta Tags settings (for stable version) a long time ago.
I just have not used the date tags in quite a while.
Thanks!
- RWE
