I have been able to rename my first 23 files. I have not been able to find out how to transfer the renamed files to the folder of my choice. In the documentation, I cannot find a default save location. The export command doesn't seem to allow me to transfer the files either. What am I missing?
Thanks,
Planorez
Thanks everyone - I found the renamed files in the folder they came from. Problem solved.
If you are making changes only to the file names, then the files will remain in the same location.
You can move the renamed files to a different location by prefixing the new name with a new path, relative or absolute.
See this article for more details:
https://www.den4b.com/wiki/ReNamer:Rena … her_folder
