#1 2020-04-04 12:23
Bryan
Custom Format preferences
One of the better password generators...however, there's a function I feel could be enhanced, and that's the 'custom format'. It has a dropdown menu, with 3 preconfigured settings, none I like, so input my own preference. However, despite looking at the 'ini' file, found no way to add my preference to the dropdown list (so I could have a list of my preferences), or a way to alter the preconfigured optrions. Perhaps in the future, it could be entered in the settings, or the 'ini' file?
#2 2020-04-06 15:36
Re: Custom Format preferences
Thank you for the feedback!
Currently, only the last used value is stored in the Settings.ini.
The ability to store several user defined password formats has been added to the list of suggested features.
