#1 2020-03-21 14:30
ngs428
Easiest Way to Update Program?
I am on 4.3.0.1 beta and want to upgrade to the latest beta.  After I download the program, I have to copy my presets folder from the older version over, then redo all my settings (if I keep the old one running to make sure I have the new one setup right there are conflicts that pop up when I try to save).
Is there an easier way to upgrade?
#2 2020-03-21 22:17
Re: Easiest Way to Update Program?
If you are using the portable version, unpack the newer version into the same location, overwriting all existing files.
If you are using the installer version, you just need to install it over the existing version.
All your settings and presets will be preserved.
#3 2020-03-22 14:09
ngs428
Worked Great.  I am using the portable version.  Thanks for the guidance!
