#1 2006-06-30 01:59
wishlish
Question about changing numbers in file names
I get a batch of files with numbers at the end- some will be name 1, some othername 02, and others yetanothername 003. I want to standardize the numbers so that they're all 3 digits long- name 001, othername 002, yetanothername 003. Any thoughts on how to do this?
#2 2006-06-30 08:53
Re: Question about changing numbers in file names
Here are the steps to achieve that:
1) Add you files;
2) Right-click the table column and select "Name Digits" from the menu;
3) Click on the new "Name Digits" column to sort files by numbers in their names;
4) Add Strip rule to strip Digits from the filename;
5) Add Serialize rule, Incremental start 1 step 1, pad to length 3, at suffix;
Done! Here is a screenshot how it should look like before renaming:
Good luck smile
#3 2006-07-01 02:38
wishlish
But I don't want to strip the numbers. The numbers may not be in order, but I still want them; think file 474, fileb 30, etc. Would that still work?
#4 2006-07-02 23:22
I'm not really sure what you are trying to do... can you explain it in more details? You could use export/import feature to show me a list of files, or a screenshot perhaps, but do explain what you are trying to do, giving examples of all different variations.
I can't help you if I don't know what you trying to achieve wink
#5 2006-07-03 13:48
wishlish
Here goes:
I get a bunch of files twice a week. Each has a different name and a number in the title. They're digital comics, so I get:
Spider-Man 26
Hulk 434
Batman 2
etc. The numbers are not sequential in any way.
I want, when I'm done, for the files to look like this:
Spider-Man 026
Hulk 434
Batman 002
I want to keep the value of the number, just format it into a three-digit number with leading zeroes.
Does that make more sense?
One other thing- sometimes there are other numbers in the title. I don't want to change those other numbers. So I might get:
Spectacular Spider-Man v2 12
I don't want
Spectacular Spider-Man v002 012
but rather
Spectacular Spider-Man v2 012.
The number I want to format will always be the last number, and will always be at the end of the filename.
#6 2006-07-05 14:07
Use this code in PascalScript rule:
  BaseName, Extension: string;
  EndDigitsCount, I: Integer;
  PAD_TO_LENGTH = 3;
procedure Inc(var A: Integer);
  A := A + 1;
  EndDigitsCount := 0;
  BaseName := WideToAnsi(WideExtractBaseName(FileName));
  Extension := WideToAnsi(WideExtractFileExt(FileName));
  for I:=Length(BaseName) downto 1 do
    if IsWideCharDigit(BaseName[i])
      then Inc(EndDigitsCount)
      else Break;
  if (EndDigitsCount > 0) and (EndDigitsCount <= PAD_TO_LENGTH) then
    while EndDigitsCount < PAD_TO_LENGTH do
      Insert('0', BaseName, I+1);
      Inc(EndDigitsCount);
  FileName := AnsiToWide(BaseName + Extension);
I tried it on you examples:
Batman 2.txt
Hulk 434.txt
Spectacular Spider-Man v2 12.txt
Spider-Man 26.txt
And here is what comes out:
Batman 002.txt
Hulk 434.txt
Spectacular Spider-Man v2 012.txt
Spider-Man 026.txt
Just the way you wanted, I think smile
#7 2006-07-06 02:07
wishlish
Yep, worked smooth as silk. Thanks for the help! Is there a PayPal address I can donate to? This program's awesome.
#8 2006-07-06 15:59
You are welcome! No, I don't have a PayPal account... so just enjoy using it, and spread the word big_smile
#9 2006-07-06 23:08
wishlish
I will- thanks!
#10 2006-07-06 23:28
dloneranger
Hi Dennis, i've got a quick question for you regarding the pascalscript you posted above
You have these lines
    if IsWideCharDigit(BaseName[I])
      else Break;
After
BaseName should be the ANSI version of the unicode filename minus the extension
But then you use
Shouldn't that return false as BaseName has already been converted to ANSI ?
I don't get it
Im not sure why the double checks are inplace, especially when I'd assume that any variety of IsWide should fail on a normal string?
I'm missing something :conf:
