#1 2020-02-06 23:29
Dirk
If not hibernate shut down 2 hours later?
How could I add this to the existing event: I want the Notebook to shut down at e.g. 2:45:00 if it did not go to hibernate at 0:45:00.
Or alternatively:
I want the Notebook to hibernate at e.g. 2:45:00 if it did not go to hibernate at 0:45:00 or if it does not hibernate to shut down 15 minutes later.
#2 2020-02-08 13:57
Re: If not hibernate shut down 2 hours later?
What do you mean by "it did not go to hibernate"?
If some application prevents it from going into the hibernation mode, then you can use the Force option.
#3 2020-02-08 22:20
Dirk
It does not hibernate. Does not get in that status / condition. It keeps on running, without changes. Or it restarts, shuts down and starts. When Win has downloaded / installed an update the Notebook shuts down and starts / installs the updates although Shutter is set to let it hibernate.
I assume, the force option will not change that. Or will it?
Is this the force option(?):
Not recommended? Sounds dangerous. Why?
#4 2020-02-10 22:02
It is probably best that you adjust your configuration of active hours in Windows 10, so that it does not auto-restart when you don't want it.
You can also try to enable the "Prevent system sleep while activated" option from the Advanced settings tab. This might prevent Windows from auto-rebooting.
If everything else fails, you can completely disable an auto-restart feature in Windows 10.
The "Force" option will not allow any application to interfere with the sleep/hibernation sequence. In your particular case it is no use.
#5 2020-02-10 22:12
Dirk
Sorry for my bad expression, it does not have to do anything with the auto-restart. When Shutter (as usual) let the Notebook hibernate it does not hibernate but install the Win updates and restart.
The only situation Win auto reboots is when there are installed updateds to be installed.
Yes, but sometimes or often I use it.
#6 2020-02-12 11:59
Can you please explain this point...
When Shutter executes the hibernation action, Windows decides to install updates and restart instead of hibernating?
#7 2020-02-12 16:10
Dirk
Sorry, if I only knew how...
Yes, a way to say it, I would say.
#8 2020-02-13 00:05
In that case, you probably need to address this in Windows, rather than in Shutter.
Maybe you should prevent Windows from disrupting the hibernation to install updates.
It seems that you are not alone with this issue, see this thread for example:
https://stackoverflow.com/questions/368 … on-session
#9 2020-02-13 00:39
Dirk
Yes, may be, but how?
I assume, there even is no hibernation. Win just installs updates and restarts the Notebook.
Thank you for the link. Oops, so it obviously hibernates indeed for some time, hadn't thought so. OK, I will try thoses measure.
Thank you!
