#1 2020-01-25 13:19
mallet
Problem with filters when renaming folders
Renamer won't rename my folders, it only stucks on files, whatever the choices I made in the filters (folder as a file, etc.)... Even when I unstick "add files within folders", files are shown...
Is there a way to send a debug log to the programmer, because I really do not understand ?
Thanks a lot.
#2 2020-01-25 13:40
mallet
Re: Problem with filters when renaming folders
Sorry, I managed to do it, applying filters prior to folder search.
I thought we could change filters on the fly, even if search was already made.
Sorry again, it's OK for me now !
#3 2020-01-27 22:55
The filter settings affect only the newly added files/folders.
You can also use the files table context menu to manage the files/folders which are already in ReNamer.
Here are few relevant articles from the wiki:
https://www.den4b.com/wiki/ReNamer:Filter_settings
https://www.den4b.com/wiki/ReNamer:Renaming_folders
#4 2020-01-28 05:57
mallet
Thanks a lot !
