I am writing to see if there is a way to use EXIF Date if exists otherwise Modified Date
The Pascal Script "Date and Time" works well for Modified Date.
The Insert, Insert Meta Tag works well for EXIF Date etc.
I cannot figure/find a way to use the EXIF Date in the Pascal script if it exists, which is what I assume needs to be done.
I then use
The Pascal Script for Serialize Duplicates
Thank you,
About which script do you talking about? (link?)
Normally we write something like: "IF Exif exists THEN use that".
So we could alter that as like : "IF Exif exists THEN use that, ELSE use FileTimeModified(FileName)"
I am using the built in Pascal script "Date and Time" slightly modified for format:
DateTime: TDateTime;
DateTime := FileTimeModified(FilePath);
FileName := WideExtractBaseName(FileName) +
FormatDateTime('yyyy-mm-dd hhmm_ss', DateTime) +
WideExtractFileExt(FileName);
Ohh, I think now I understood.
I cannot figure/find a way to use the EXIF Date in the Pascal script ...
See
> https://www.den4b.com/wiki/ReNamer
> https://www.den4b.com/wiki/ReNamer:Scripts
> 3rd party libraries > Extract EXIF/IPTC/XMP tags from any images
>> and there f.ex. > http://www.den4b.com/forum/viewtopic.php?id=407
if Length(DateEXIF) > 0 then
FileName := DateEXIF[0] + '-' + DateEXIF[1] + '-' + DateEXIF[2] + ' ' +
DateEXIF[3] + '.' + DateEXIF[4] + '.' + DateEXIF[5] +
For your issue, try to change
to
end
ELSE
showmessage('no exif info, use FileTimeModified');
As far as I understand your issue, I can imagine smtg like this will help you:
IF there are EXIF information to extract, use that information
to insert the date into the filename, ELSE use the files Modified Date instead:
{den4b
Insert EXIF/IPTC/XMP tags from any images
Here changed to add an ELSE cause}
EXIV = '"exiv2.exe"';
TAG = 'Image timestamp\s*\:\s*(.*?)[\r\n]';
Command, Output: String;
Matches, DateEXIF: TStringsArray;
Command := EXIV+' "'+FilePath+'"';
Matches := SubMatchesRegEx(Output, TAG, False);
DateEXIF := SubMatchesRegEx(Matches[0], '(.+)\:(.+)\:(.+)\ (.+)\:(.+)\:(.+)', False);
end
ELSE
//showmessage('no exif');
FileName := WideExtractBaseName(FileName) + '_' +
Some may want to alter the "FileName :=" order of parts.
HTH? . . . or any more questions?
Hello, that works very well. It seems I may have some files that have Exif data that is blank, but I am going to see if I can play with it and see if I can make this work a little better for me, I may post another question, but when I have more time I will try. Thank you.
What is the problem with such files? What do they show?
Do you say there is smtg in "DateEXIF" but white spaces only?
Maybe try to add:
showmessage('exif 1: __>' + Matches + '<__');
showmessage('exif 2: __>' + DateEXIF+ '<__');
(test that only on a few files!)
Hello, I am writing to say I believe the proposed solution #4 worked correctly and well for everything. Great job and thank you.
Thank you for the feedback, Andrew.
