#1 2020-01-03 19:54
zellneo
Two sets of events and actions
Hi! I did a macro to close two programs windows. I wanna do that 5 minutes later open the same two programs. someone idea? I ve pro edition.Thanks.
#2 2020-01-04 14:53
Re: Two sets of events and actions
You can chain together multiple presets using the "Run Preset" action.
Create a 2nd preset that waits for 5 minutes and then starts the desired programs.
At the end of your 1st preset add a "Run Preset" action which starts your 2nd preset.
