#1 2019-11-10 16:28
eR@SeR
Wrong rule selection in Edit rule window
Hi Денис,
I noticed that wrong rule selection is shown in Edit rule dialog. Steps are:
1. Open ReNamer with empty rules area
2. Click on "+ Add" button or rules area
3. Click on "Insert" or any other available rule and click on "Add rule" button
4. Repeat step 2
5. Click on any other available rule that is not previously added and click on "Add rule" button
6. Double click on the first added rule to edit it
The selection on the left panel is on the last added rule, while configuration view is from 1st one. So if a user adds more rules and tries to edit any of non-last added rule, name from last added rule is shown.
Reproduced on Windows 7 (might be on Windows 10 also - didn't check), ReNamer 7.1.0.4 Beta.
P.S. When the user clicks on added rule to edit it and immediately presses Esc button two or more times, it won't be closed on 1st press. Is this intended or an issue?
#2 2019-11-10 21:29
Rnmr
Re: Wrong rule selection in Edit rule window
I noticed this before but haven't come across again to test/report.
I just tested and, yes, it still does it.
- RWE
#3 2019-11-20 17:21
Thank you for reporting.
This bug has been confirmed and it will get fixed.
#4 2019-11-26 23:24
#5 2019-11-29 00:18
eR@SeR
It is fixed. Thank you.
