#1 2019-09-24 01:27
Cleoss
Wiki - function UTF8Encode: utf8 vs Unicode disambig
Hey, Den! Can you tell me a difference between Unicode and Unicode's subformat UTF-8 there (in functions for utf8-coding)?
As I see, general Unicode format in wiki is meant to be UTF-16, aint it? Otherwise it seems alike to me (utf8 and utf).
#2 2019-09-24 14:09
Cleoss
Re: Wiki - function UTF8Encode: utf8 vs Unicode disambig
In the same page a yet another disambiguation needs to be resolved:
wiki wrote:
If no BOM found then text is interpreted as ANSI encoding.
Which one encodings of ANSI? Obviously, Win-1252 for latin symbols? Or any other of them?
Same as when it's told 'Unicode', it stays unclear which version of UTF is used (utf7/ utf8/ utf8bom/ utf16le/ utf16be etc).
However, it looks something scary for me that user can't use predicted encoding whilst using that function.
big_smile Sorry for my French, user is using a use.
#3 2019-09-24 14:12
Cleoss
Telling that I mean that the Wiki page needs some clarification. Not that me's needing an explanation of the difference.
#4 2019-10-01 17:19
