Ideal workflow when working hard is just drop files on icon of droplet that has embedded script and tht renames files silently (dialog as an option).
Adobe Photoshop has such feature. It is called droplet. You make Action and then create small App that internally holds this action and runs it for every file dropped on its icon.
As far as i know no PC renamer has such a feature. I saw it just at Apple's App called DropRename.
This feature already exists in ReNamer.
You can create shortcuts (links) to presets, and drop files directly on to these shortcuts to automatically process files in accordance with a preset.
Documentation for the "Create Links" option:
ReNamer:Main_menu#Presets_menu
Documentation for the unattended renaming:
ReNamer:Command_Line
Cool! Thank you!
