I’m trying to batch rename a group of folders with the beginning and end file names of the contents within it. For example, a set of files 0001-9999 live in folder(new folder). I want the (new folder) to be named _0001_9999_. It would ideal to do this for multiple folders at a time.
This can be achieved using the Pascal Script rule in ReNamer.
Can you provide a few example filenames, to help us establish a pattern for extracting the necessary numbers?
(New Folder, New Folder 2, New Folder 3,...etc) Inside each folder will be a list of files for example, CF451161, CF451162, CF451163...etc. or files named like this _04A7657, _04A7658, _04A7659.. etc. The last four digits of each file are usually sequential. I would like to batch name the parent folder for each list of files with the first and last file name. So the New Folder's will be renamed like this (_CF451161_CR45163) and (_04A7657_04A7659)
Ok, lets consider the following paths:
C:\Temp\Nbot\A\CF451161.txt
C:\Temp\Nbot\A\CF451162.txt
C:\Temp\Nbot\A\CF451163.txt
C:\Temp\Nbot\B\_04A7657.txt
C:\Temp\Nbot\B\_04A7658.txt
C:\Temp\Nbot\B\_04A7659.txt
Add your folders for renaming as folders (not as files), by adjusting the filter settings.
Add a Pascal Script rule with a script included below. Basically, it finds all contained files, sorts them and uses the first and last filenames for renaming the parent folder.
The new names of folders should like the following:
C:\Temp\Nbot\A -> CF451161_CF451163
C:\Temp\Nbot\B -> _04A7657__04A7659
The script to achieve this:
{ Rename folders using MIN & MAX contained filenames }
FirstFile, LastFile: WideString;
Files: TWideStringArray;
I: Integer;
SetLength(Files, 0);
WideScanDirForFiles(FilePath, Files, False, False, False, '*');
if Length(Files) > 0 then
FirstFile := Files[0];
LastFile := FirstFile;
for I := 1 to Length(Files) - 1 do
if WideCompareText(FirstFile, Files[I]) > 0 then
FirstFile := Files[I];
if WideCompareText(LastFile, Files[I]) < 0 then
LastFile := Files[I];
FileName := WideExtractBaseName(FirstFile) + '_' + WideExtractBaseName(LastFile);
This is great! Thanks!
