#1 2019-09-05 16:18
jeffli
Is it possible to support Unicode comments in Pascal script?
Hi Denis,
Is it possible to support multi-language remark in Pascal script?
I write Chinese remark in the Pascal script, but it displays the symbol "?" in it like this:
http://www.den4b.com/forum/img/members/4360/PIC__35.jpg
Jeff
#2 2019-09-05 17:29
Re: Is it possible to support Unicode comments in Pascal script?
Yes, it is possible, but you need to have at least ReNamer 7.1.
This script will be saved in UTF8 format with BOM.
#3 2019-09-06 00:09
jeffli
It works, I convert the .pas script to UTF-8-CODING in Notepad++, then select the .pas script in ReNamer 7.1. it does not display "?" anymore.
Thank you, Denis.
Jeff
