#1 2019-08-16 04:07
dzhay
Document Management System Email ID codes
Hi
I have to batch rename hundreds of emails, many of which come from a professional services firm using a document management system (I'm not sure which one). The document management system inserts into each email topic (usually at the end) a string as follows [XX-XXFIDZZZZZZZ].
XX represents the name of the firm in 2 letter abbreviation.
FID is the exact string.
and ZZZZZZZZ is the actual document number.
I need to remove this from every file name, but I can't figure out how to do it. I've tried the remove function but it hasn't worked.
Thanks in advance for any help!
#2 2019-08-16 07:47
Re: Document Management System Email ID codes
The simplest way is to use the Clean Up rule to strip the contents of [...] brackets. However, it will strip all occurrences of [...] brackets.
If you need the rule to be more specific by matching a more specific pattern, then you need to use the Regular Expressions rule, like follows.
Expression: \s+\[\w{2}\-\w{5}\d{7}\]
Replace: (empty)
This would convert "Hello [World] [AB-CDXYZ1234567]" to "Hello [World]", leaving unmatched brackets unaffected.
#3 2019-08-16 14:25
Another idea, as far as I understood ( it's always a good idea to provide real before/after examples)
follows [XX-XXFIDZZZZZZZ] - Kopie.txt
string [as] follows [XX-XXFIDZZZZZZZ] - [Kopie].txt
string as follows [XX-XXFIDZZZZZZZ].txt
follows - Kopie.txt
string [as] follows - [Kopie].txt
string as follows.txt
Wanted:
Match and remove "[.....-..FID......]"
So "[" and "-" and "FID" and "]" are my anchor points here.
Use:
RegEx rule
http://www.den4b.com/wiki/ReNamer:Rules:RegEx
Express: (.*)\s\[.+-..FID.+?](.*)
Replace: $1$2
HTH? big_smile
