#1 2019-08-07 02:43
wenmin92
Can download url be fixed for Scoop package management?
Recently, I am addicted to scoop, a package management on Windows.
I like Renamer very much. I think if she is more convenient to manage on the scoop bucket, I tried to make her a manifest. Finally, I found that the download link is not reliable, so I can't finish it.
Can this be change a bit? THX.
#2 2019-08-07 09:33
Re: Can download url be fixed for Scoop package management?
Sure, something similar was already done for the Chocolatey package management.
Take a download URL and append a special parameter to the end "?token=scoop". Please use this token ONLY for the Scoop package.
See also the relevant Chocolatey packages for the reference:
https://chocolatey.org/packages/renamer.install
https://chocolatey.org/packages/renamer.portable
#3 2019-08-07 09:38
wenmin92
Thank you very much for your support.
I am also looking for support from scoop, hoping to solve this problem from another direction....
Url support dynamic parameter or use a script modify url · Issue #3586 · lukesampson/scoop
#4 2019-08-07 10:36
The version-less URLs will always download the latest version.
But you can also link to a specific version, see the list of all downloads:
https://www.den4b.com/downloads/renamer
#5 2019-08-07 11:20
wenmin92
This, I have try that, it could. THX.
Some one has create the manifest. See lukesampson/scoop-extras#2585
