#1 2019-05-14 09:31
BadDogTitan
Remove Numbers in Brackets
I have thousands of files in the following format:
Filename 1 (A101 8.2 S3)
Filename 2 (A5 9 R14B)
Filename 3 (A45 27 M24)
How would I rename them to:
Filename 1 (S3)
Filename 2 (R14B)
Filename 3 (M24)
I know RegEx is the answer, just can't figure it out.
Thanks.
#2 2019-05-14 13:03
Re: Remove Numbers in Brackets
The following regular expression should do the job...
Expression: \(.*?\b([\w\d]+)\)
Replace: ($1)
Sample input:
Filename 5 (TEST)
Output:
Filename 1 (S3)
Filename 2 (R14B)
Filename 3 (M24)
Filename 5 (TEST)
#3 2019-05-24 13:28
BadDogTitan
Fantastic den4b! On using it, I realize the output would look better without the brackets.
How would I return just the number?
#4 2019-05-24 13:59
Try to adjust the "Replace:" statement.
Just play around, it's easy:)
#5 2019-05-28 19:35
And, BadDogTitan, how did it worked out?
#6 2019-06-09 20:05
BadDogTitan
Sorry, Stefan. Haven't been back for a while. Worked out famously. Also, I found the Regular Expression tool on the website, which is a great help.
