#1 2019-03-26 16:20
narayan
ReNamer gives error while renaming pdf files using Pascal Script
When I try the pdf renaming PascalScript, ReNamer gives this error:
Preview process has been terminated due to a critical error:
Pascal Script Execute:
[Line 13] Exception: Access violation
I updated the file to the latest beta (dated 26-3-2019), but I get the same error.
Earlier the same script worked well.
(I have placed the pdfinfo.exe in the same folder as ReNamer.exe file.)
#2 2019-03-26 16:24
narayan
Re: ReNamer gives error while renaming pdf files using Pascal Script
Since the forum has multiple versions of the pdf name script, I am reproducing my script below:
{ Extract PDF tag }
  PDF_INFO = 'pdfinfo.exe';
  PDF_TAG = 'Title';
function ExtractTagPDF(const Info, Tag: string): string;
  Lines: TStringsArray;
  I, Delim: Integer;
  Result := '';
  Lines := WideSplitString(Info, #13#10);
  for I := 0 to Length(Lines)-1 do
  if WideSameText(Tag, Copy(Lines[i], 1, Length(Tag))) then
    Delim := WidePos(':', Lines[i]);
    if Delim > 0 then
      Result := WideCopy(Lines[i], Delim+1, WideLength(Lines[i]));
      Result := Trim(Result);
  Command, Output: string;
  TagValue: string;
  Command := '"'+PDF_INFO+'" "'+FilePath+'"';
  ExecConsoleApp(Command, Output);
  TagValue := ExtractTagPDF(Output, PDF_TAG);
  FileName := TagValue + WideExtractFileExt(FileName);
#3 2019-03-26 16:25
narayan
Line#13 seems to be this: Lines := WideSplitString(Info, #13#10);
#4 2019-03-26 19:17
Lines := WideSplitString(...);
Do you see the error?
If not, see the list of functions:
http://www.den4b.com/wiki/ReNamer:Pasca … :Functions
I will take a look later on if you got it ;-)
#5 2019-03-27 04:48
Thanks for reporting.
It appears to be a significant interoperability issue between the newer compiler (FPC 3) and the scripting engine (Pascal Script).
This issue seems to affect all pascal script functions which return dynamic arrays, such as WideSplitString.
The investigation continues...
#6 2019-04-24 06:03
narayan
Hi
Is there a workaround for this issue? IMHO reverting to older version is fine as long as it works.
With the latest issue, we cannot use Pascalscript for pdf-renaming at all.
My collection of downloaded pdf files is increasing day-by-day, so this is a major issue for me!
#7 2019-04-24 14:55
Yes, there is, and it is already available in ReNamer v7.0.0.4 Beta cool
http://www.den4b.com/changelogs/renamer/7..7.0.0.4
