#1 2019-02-11 19:43
poop
Event - on mouse hover
hi,
how I can to add event' when the mouse hover on something, or if I type something, and than make action?
many thanks.
#2 2019-02-12 15:44
Re: Event - on mouse hover
There is currently no such event which would allow you to trigger actions when the mouse is moved or a key is pressed.
Can you please provide a complete use case example? What exactly is that "something" ?
#3 2019-02-12 17:42
poop
hi,
many thanks for the reply.
something I mean, for example, that if I put the mouse on specific process in the task manager, and the shutter  will make action, and will close the task manager.
