#1 2019-01-27 09:36
melsofft
Swap names problem
Hello there
I have files like this:
Caragiale, Ion Luca - Opere alese vol.1.docx
to rename in
Ion Luca Caragiale - Opere alese vol.1.docx
I try with delimiters "," and $2 $1 and the result is:
Ion Luca - Opere alese vol.1 Caragiale.docx
Where is the mistake??? What to do?
#2 2019-01-27 09:56
Re: Swap names problem
The Rearrange rule works as expected in your case, but perhaps not as intended by you.
If you use "," as the delimiter, your filename will get split into 2 parts, highlighted as RED and BLUE:
So then if you swap them around using "$2 $1" pattern, you will get:
Instead, I think you what to split it into 3 parts, so you would use an exact pattern of delimiters ", | - " to get parts:
And then rearrange using "$2 $1 - $3" pattern to get:
#3 2019-01-27 13:28
melsofft
Thank you very much for your help, is oh so simple this program...
smile
