#1 2019-01-03 06:46
lizhi.io.Hue
About activation of portable Version
Hi, I'm from China and I wanna buy ReNamer Pro from DIGITALYCHEE (lizhi.io)
I have a question about that Can the single device version of the activation code be activated in the portable version?
Thanks~
#2 2019-01-03 10:34
Re: About activation of portable Version
You can, but the activation applies only to the one computer where the activation has occurred. You can use either the installer or the portable version, or both, on that one computer.
Note that if you move the portable version to a different computer, it will not be activated.
