#1 2018-11-22 09:36
icarson
MP4 Tag Library Integration
Hi Guys
A post in 2016 entitled "Tags in iTunes mp4 files" hints at the possibility of integrating an MP4 Tag Library into ReNamer once the new compiler is in use.
I was wondering if the compiler change happened and if so how the integration is to be achieved. I have downloaded the library suggested in the post but am uncertain how to proceed.
Thanks in advance
Regards
Ian Carson
#2 2018-11-22 21:40
Re: MP4 Tag Library Integration
The complier change has happened, but the MP4 Tag Library has not been integrated into ReNamer yet.
However, you can extract MP4 tags in ReNamer via a script and an external tool such as MediaInfo library.
You can see a sample script here:
http://www.den4b.com/wiki/ReNamer:Scripts:MediaInfo
