#1 2018-10-01 09:53
narayan
Unable to change case in files stored in pen drive
I am facing this problem even outside Renamer, so this may be actually an OS issue.
I have a pen drive.
If I want to only change the case of a file name, I am not able to do that.
The command fails silently.
But if I move the same files to any other hard disk (intrernal/external), it works.
To make this work on the pen drive, I have to insert/delete a character, and change the case in a single operation, the renaming works.
After that, I have to reverse the additional change I made, in a subsequent operation.
This is happening on two PCs that are totally dissimilar:
My desktop has 32-bit Professional version of Windows 10.
My laptop has 64-bit home edition of Windows 10.
What could be the reason?
#2 2018-10-01 09:57
narayan
Re: Unable to change case in files stored in pen drive
BTW I just noticed that if I try to insert a space at the end of the name, it does not work.
It accepts the space anywhere in the middle of the name.
#3 2018-10-01 23:05
These are OS and file system limitations.
Microsoft wrote:
Do not end a file or directory name with a space or a period.
^ https://docs.microsoft.com/en-us/window … ing-a-file
On top of that, different file systems may handle the case changes differently. Most pen drive use FAT32 for compatibility reasons, which is an ancient file system with a whole bunch of limitations and quite different handling of case sensitive changes.
^ https://en.wikipedia.org/wiki/Case_sensitivity
#4 2018-10-03 06:34
narayan
Spot on!
The drive is FAT 32. Will change the formatting to see if that helps.
Thanks a lot for the tips!
