#1 2018-10-01 09:40
narayan
If I enter a comma an the end of Case fragment list, name is deleted
In the Case Rule, if I enter a comma at the end of the word-list in the Force case for fragments box, Renamer deletes all file names.
Then it validates the new names, and prevents a duplication of names by inserting dummy serialized numbers in parenthesis.
Like this:
(1).ext
(2).ext
(3).ext
etc.
(The extensions are not affected, because I had omitted them from the rule).
Desired: Renamer should ignore the last comma in the Force case for fragments box.
Any user can make this mistake, and then he won't know what went wrong.
I had faced this issue earlier, and could not understand what went wrong.
So I started all over again, and did not repeat the mistake the second time (by chance).
This time I realized the problem by a happy chance.
#2 2018-10-01 23:48
Re: If I enter a comma an the end of Case fragment list, name is deleted
Well spotted!
Calling it an undesired behaviour is rather mild. This is a bug in all its glory, and it will be fixed in the next dev version.
Thanks for reporting.
