#1 2018-07-28 14:54
mark7
Hijri Calendar
Thank you for this great app renamer
I have a question
How can i add another calendar Hijri date . Because i have files that need to be renemed as following
YYYY.MM.DD........
I did rename files in Gergorean Calendar. But i need Hijri Calendar
#2 2018-07-29 12:43
Re: Hijri Calendar
You could use the Pascal Script rule to convert dates between different calendars.
I am not familiar with Hijri Calendar specifically, but if you could describe the conversion rules (the algorithm), we could help you with the script.
